Hey all:
Alright... I've searched around and I can't seem to find exactly what I'm looking for, but could be looking in the wrong places.
I have a 95 5.8 Bronco. Recently, I can't get it to start.
When I turn the key, I hear the fuel pump engage and the motor turns but it keeps turning and doesn't start.
Some background: Prior to this issue I did have an idle issue while driving and I thought I resolved it but I thought during heavy acceleration that I would smell rich fuel... almost smelt like rotten egg. Originally, once warmed up or driving for a bit, the idle would kind of jump around... really high while stopped in drive and higher while in park... sometimes driving it would kind of jolt the transmission. I did a series of tests and troubleshooting:
A. Tried to pull codes. Engine light would only come on momentarily during strange idle instances. When I pulled codes I didn't get anything except a high idle.
B. Removed and cleaned IAC valve - same issues.
C. Tested the TPS and got strange readings. Once I reconnected it however, the idle problem went away. Via readings within the forum I decided it must have been a dirty or bad connector and I cleaned the connections. The idle problem was gone... however I would occasionally smell the rich fuel I indicated above.
Now.... it turns and turns upon trying to start but just won't go. Not sure how to safely test spark (or if I should yet do so) and the fuel pump seems to be working (I hear a 3 - 4 second whine when I turn the key to the on position). Not really sure where to go next. I've read in other posts and on Ford Fuel Injection that the TPS can cause a non-start and I'm skeptical that could be the problem due to the above mentioned issues... just not sure if there are things I should do before I go purchase parts.
Suggestions? Any help is greatly appreciated!
