Hey guys. Got my 351 swap running over the holiday. Anyway I have a tweecer and got a tune from tweecer with it fired right up with so I'm happy. Question is it didn't occur to me to tell Mike glover that my 302 had a knock sensor where a 351 doesn't. I'm not getting a idiot light or anything but will it pull timing anyway? Should I disable it in the tweecer or leave it alone? If I should disable it how do I go about it? Thanks in advance fellas. I'll put a video up of it running at some point sense alot of u guys helped choose parts for my build.
Charlie don't surf..
'92 Ford Bronco XLT
I have the tweecer as well and converted from a 302 to 351, no need to worry about the knock sensor. There may be a line under the scalars to set it to off, but I can't remember off the top of my head.
did you use the way1 EEC?
Yes sir I used the way1. I saw when I was browsing through the tune Mike sent me there was a place to disable it but I wasn't sure if it would effect anything or even matter anyway. So your saying just leave it alone then?
Right now it's just unplugged completly
'92 Ford Bronco XLT
yes, just leave it alone. it's not going to throw a code or anything being disconnected.
Ya Mike just emailed me back. He said the same thing I can turn it off if I want to but it won't matter either way. I'll prolly shut it off next time I'm playing with something else.
