First off I want to thank Bob (aka Slickerthanyou) very much for the help, and I appreciate the help everyone else contributed!:thumbup
Running both is a waste of electricity (yes, it still costs gas to produce it), but you're right: their pressures won't add.
Ok, I figured they couldn't add together, but wasn't sure.
The wiring is easier than the fuel lines!
3 wire sending units share a ground for the pump and float
4 wire sending units have a separate ground for each
Solder the 2 grounds together to swap in the wrong tank
If you're going to swap from 2pumps to a high pressure tank pump. You should also remove that small fuel reservoir, it will screw up the tank pump from providing adequate pressure to the engine. You'll have to buy the fuel line ends and nylon line. Then make a new longer line that bypasses the unused parts.
Yea, the wiring was very easy, it took longer to read (for me) the two wiring diagrams than it did to splice in the other pig tail.
After Spliceing it in, tested it with the koeo and I got 12v for the red (pos) wire.
As for the fuel lines FROM the tank TO the resivor on the frame rail, they are nylon also, so Im not very concerned, but when it gets warmer outside, things under there WILL be changed.
AND:
Not entirely sure who did the write up about cutting an access panel in the floor for tank access (was it steve83?) but I did and I am very happy I cut the hole in the floor!! (Don't say that very often.)
Just one question:
Like I said above, I will change the fuel line setup as soon as I can, but I wanted to know if there will be any long term NEGITIVE effects running 2 hi pressure pumps. This setup is temporary until I have the chance to run new line for the entire fuel system. Will it last about 3 months or so?
Again, thanks for all the help!!:beer
P.S: And I think I got my vibration problems solved!:chili: (Loose pinion nut and a very very dry slip joint)
