1: I just recently changed my shocks to Ranch RS 5000's....it required 6 shocks (4 front 2 back) but I only changed the 2 back & the main 2 up front. I read recently on FSB that there was no reason to change all 4 up front. The problem now is, it shaking quite bad when reaching speeds between 60-70.....What is wrong & what do yall suggest I do???
2: There is quite a bit of hesitation when first starting out....I just recently did a tune up( spark plugs, wires, rotor, etc....) changed the fuel filter, air filter, oil, transmission fluid & filter. What would be causing this.? what should I do???
Thanks for the replies...if my sig does not state it: 1994 EB 5.8 V/8
Once again Thanks, Ben
