SnowTom... you will probably notice on the Fuse Block Diagram that miesk5 supplied, there are 3 fuses that wire to the radio; 8, 10, and 11. For radio presets you're needing the 12 volt constant... should be 8. I'm what I call an "over-chcecker". Might be worthwhile to (obviously) first check ALL fuses then take a multi-meter and make sure there is 12 volts at #8 when the ignition is off and the key is NOT in the ignition.
Being a 21 year old vehicle, there's no telling what's happened with the Radio wires, either.... especially if there was a previous owner... they could have rewired the constant to a different location... no telling. The wire could be loose behind your radio, shorting out against metal behind the dash, etc. After you've check the fuses and verified there is in fact 12 volts constant at the fuse box, start looking for 12 volt constant behind the radio. If the wire is there without 12v but you have it at the fuse block, test continuity between the wire and ground. If you start testing continuity directly to the fuse box, disconnect the negative battery lead first just to be safe. You can also jump a test wire from the #8 fuse directly to the 12v constant on the radio to verify it's not the radio malfunctioning.
But again... I'm an "over-checker" that has a problem with wanting to know why! lol. No constant behind the radio but good at the fuse box... new wire, done. I just tend to look deeper. Hope the info helps.
