RESIDENT ASSHOLE
Have any of you guys had any experience with them . You know the small ones that are out( radio shack , motorola,cobra).Some claim 2 - 8 miles.I am trying to find out so I can buy some for my kids to keep track of them while they are outside playing.Cell phones cost too much for four.Even with the plans they offer . Pre-paid is out also.I live in good old fashion subdivision with quite a few houses , so I don't know if I get the better ones(longer distance)ones would be better . Thanks
Some assembly required!
I work on commercial two way radios, specifically Motorola, for a living, but I think what you're talking about are called FRS radios. It stands for Family Radio Service. The manufacturers reports of their range is GREATLY exagerated. No way in hell you're geting 2 miles if you have any kind of obstructions in the path. They can claim the big range numbers because it is possible under ideal conditions, i.e. you're on a mountain top and have a clear line of sight to them and have a fully charged battery. These FRS radios are limited to a max output power by the FCC, 1/2 watt ERP if I recall, and you are specifically forbidden from using any kind of power booster or improved antenna system. The FCC intended these to be a very range-limited device. If your kids will be within a few blocks you'll probably be okay with them, if they'll be half way across town you can forget it. The things are cheap enough, just get a set and try them out to see if they'll meet your needs. I've seen them as cheap as $30 for a pair.
I have a bunch of them, and I can tell you the cheaper they are the more they overrate the range. I have like 3 sets of Cobra's that were about $60 for a pair if I rememberright and they work clearly up to about 1/2 mile away if your going through mountains and trees. At the flat open land they will go about 2 miles. When I bought them, they said they were good for 5 miles. Then I have a new set of Motorola radios thart was about $250 and it was advertised with a 5 mile range and they will actually go 5 miles. In the trees they will do about 1.5 miles to 2 miles quiet breaking up.
Got a pair at target and they work extremely well. They work well within 'bout 2 blocks. But they work fine within that range.
Here at the ski resort, everybody carries these things now, and I will second Mike's advice that the better motorolas and "brand names" do seem to work better. A few of our staff that carry them to keep occupied on lifty shifts are getting reasonable reception from summit to base and everywhere in between (frontside) which is at least 5 miles, but flawless line of sight. If they ski around back however, they loose it completely. The Cobras and other knockoffs don't seem to work as well.
I've got uniden radios that say they are good for 3 miles. Hardy har har! Maybe 3 blocks. I use them to track my youngin' and they work ok because all his buds live close by. We tried them at about a mile and no go.
