1 - 9 of 9 Posts
Summer is here and im trying to fix my A/C...
My first problem was i was missing the high side hose off the compressor. $70 later, im back in business. I try to charge the A/C, and come to find out, my A/C compressor isnt cutting on. Had to ghetto a wire system to the compressor to the battery just to charge it. I buy 3 cans of R134A at $8 each, fill her up, and yaaa!! i get cold A/C! Shut off the engine and i hear a hissing. I have a pin hole in the high side hose. So now i need a new high side hose. Looks like more window rolling down. :banghead.
Not a big rant, but absolutely ticked me off. Rant over.
AC is great when it works, but it starts to be a real pain in the ass when there is leaks. It leaked out on my f150 and I just charged it back up and it only lasted a week. I said **** it after that.
Kitteh Commandaar!
Quick way to find out if your AC will hold a charge is to pull a vacum on it...and see if it holds steady. If so chances are it'll hold refrigerent...
KC
that sucks, but thank god your not out here in AZ it's been 110 out here past few days:thumbup
Driving Stuff Henry Built
KC
:stupid
And you ought to vacuum it anyway to remove any moisture before charging it. The tiniest amount of moisture can cause it to not work.
Kitteh Commandaar!
no u cant use the shop vac for it
I can't tell if you're being sarcastic or not, but when you pull a vacume on an AC system, it will pull the moisture out of the AC system. Water boils in a vacume, therefore if you do this on an AC system, the moisture turns to vapor/steam and is removed from the AC lines/pump accumulator etc...
KC
House of Windsor 4ever!
Yup. Pull it down to 30" of vacuum and watch the gauge for about 1 hour. If the needle moves at all, you have a leak. If not, then the vacuum will pull the refrigerant into the system. Problem solved.
1 - 9 of 9 Posts
