1 - 20 of 38 Posts
Specs:
79, 400, C6, 203 , 37" MTR's, Sky Shackle Hangers, Stock JC Whitney Springs, BDS 4" Front Coils, Cage Arms and significant cutting
Working on:
Front D-shaft, new shackles, knuckle under, new steering components, cage, fuel cell, a bit more cutting, rear bumper (BMC style), front winch mount and winch, move the rear hanger a bit forward, fully weld the Cage rear mounts and paint, shocks and fix whatever breaks. I'm also going to lose the top and tailgate once the cage and fuel cell are done.
Ultimately
Doubler w/205, pick up a 10.25 or a 14 bolt, front D60 and put it in this truck and move all the front end components over to my 92 (if somebody doesn't fawking buy it..damnnit.) http://fullsizebronco.com/forum/showthread.php?t=25552
Some Pics........
Last Winter
Today
:beer
looks great :thumbup
[chico] Lookeeeeen Goooood! [/chico]
looking good. gotta love the primer grey.
Mr. Asks Alot
looks good and that thing as ugly as shit before you got to it :toothless
Project Re-Build & Finish
Those Cage arms look alot better then the ones sitting in my shop. :brownbag
If I knew you were into that kinda work rebuilding Broncos I could have given you what was left of this.
Discussion Starter #14
Those pics make that body look 200% better than it does in person. It's not getting anymore paint than what it has unless we rattle can it. It is quite a bit rougher than it looks since all I did for the body prep was sand all the rust spots and coat with that black crap that retards rust. Cut out everything that was on the fenders. Then I had our body shop paint man shoot the primer. All I can say is air sanders rock! Paint and rust disappear with those things.
Most of the tough work was getting the rusted bolts loose or cut off and getting the axles shafts loose to clean out the axle tubes. This thing must have sat in mud for a while.
I can say that with 37's I can turn lock to lock and not rub those Cage arms. The arms are worth more than the rest of the truck.
Had a mullet in HS
Can I ask a stupid question?
Whats this setup?
Is this the F 250 reverse mount I hear about? or is it something else?
Thats the sky shackle hanger. Uses original bolt holes and gives you 4-5 (I think) inches of lift. Try a search I know theres tons of threads on them.
1 - 20 of 38 Posts
