I got a 90 bronco, fixing some things to make it road legal...one of them is the horn doesn't work.
I press the horn I here a click (assuming) from the dash, now teh real problem.. WHERE THE HELL IS THE HORN!??:scratchhe:scratchhe:scratchhe:scratchhe:scratchhe I'm pretty sure I looked every under the hood.....and splash shields in the fenders.
Lick my balls
Lay on your back under the radiator toward the driver's side. You will see a pair of horns mounted high up between the radiator support and the grille.
Check the wiring for power when activating the steering wheel horn pad. Check for a good fuse and relay. Remove and tap horns on the ground to clean out any debris accumulated inside. Adjust the diaphram screws on the horns, if required.
If you have power and the horns still do not work, consider horn replacement with junk yard, Hella, etc.
I can take a picture tomorrow when I get home from work, if you require one...
...I feel dumb, looked right over em. thanks a bunch guys! Diagnostics begin tomorrow!
