1 - 12 of 12 Posts
1992 Ford Eddie Bauer Bronco 5.0
So when I was looking at my truck this morning, I noticed a cut vacuum hose. Trying to figure out how to repair it any ideas? Also what is is it connected too and what does it do?
Automotive tire Motor vehicle Helmet Gas Automotive exterior
Motor vehicle Automotive exterior Automotive fuel system Gas Automotive wheel system
Military camouflage Automotive tire Camouflage Motor vehicle Ballistic vest
Motor vehicle Auto part Gas Electrical wiring Metal
1994 Bronco XLT 5.0, E4OD, 31x10.5R15 BF Goodrich A/T on OEM Rims, Rust Resto w/Custom Suspension
Based on location, maybe your A/C door actuator? It's a typical failure as shown on mine. A pic showing more of the engine bay would be helpful.
Motor vehicle Automotive tire Hood Material property Automotive exterior
Edti: Scratch this. Just realized you were showing both ends. I'm not sure what that goes to, but will follow to learn.
1996 Bronco XLT, 5.8, Auto Everything.
amazon sells "variety packs" of silicon vacuum tubing. I suspect teh local auto parts store will as well. find a size that snugly fits over the cut ends and slip it over for a quick patch.
Vacuum lines carry negative pressure, so they don't "blow out" like pressurized lines do. Makes quick-n-dirty repairs rather simple.
1995 Ford Bronco, Automatic V8 5.8L, Eddie Bauer
I believe that one is needed for the actuator that is underneath the glove box.
1990 EB, 5.0
Should be 1/4 inch tubing. Disconnect the old connector from the black box and hook up a rubber/silicon line directly on it, then the other end should slide over the remaining hard plastic line. No big deal. Should definitley replace ALL your vacuum lines with rubber or silicon.
1986 Bronco Eddie Bauer 5.0 mostly stock
That is a clean cut...i don't even know how someone would accidentally do that...or why someone would do it intentionally.
That is an HVAC line, probably runs one of the blend doors or the defrost flap. But as mentioned, simple simple fix, slide both ends up in some 1/4 tubing...
2014 Ford Explorer Sport
As a few others correctly identified that black vacuum hose supplies vacuum to the entire HVAC system.
Reactions: sadboy and miesk5
Yo sad boy,
If vacuum hoses are still colored;
1 (White) Recirc.
2 (Red) Full Floor
3 (Yellow) Panel
4 (Blue) Mix
5 (Black) Source at intake manifo,manifold, tree
Reactions: sadboy
Discussion Starter · #9 ·
Thank you all for your input and help :)
Ya I was thinking about that also, it is a clean cut. So many questions as to whom would have done that.
It looks like it was either intentionally cut to get the ground strap by it, or the ground stop was laid over it and wore through [cleanly] somehow, neither of which makes sense unless a PO didn't realize the nearby end could be temporarily disconnected.
95 5.8L MAF XLT, Hedman Shorties/MF SS Y & Muff, E4OD, Man hubs, KYB Quads, 31x10.5x15, 311K miles
There are 2 ways to go in repairing it: #1 cut a piece of rubber hose that fits over the plastic tubing tightly and be done with it. #2 pull the plastic tubing out of the rubber fitting then insert the cut piece of plastic tubing in the rubber fitting.
'88 XLT. 2" lift, 3G, Saginaw Pump, Headers, High flow 3" cat, 3" exhaust, 6 litre tune, K&N
I bet fixing that will smooth out your idle some. That was an open vacuum leak directly to the intake manifold.
1 - 12 of 12 Posts
