1 - 1 of 1 Posts
Since I picked up the beast I've replaced the starter, water pump, ignition switch actuator, smog pump, ignition coil, ECM Module, alternator and a new tension idler pulley. :beer
Also, I got the rewindow to lower and stuff. It was just frozen and the switch is worn out. I have to go all hulk style when I press on it. :rockon I'll pick up a new one from LMC next week.
Now I just need to fix the play in the steering. Redo the entire exhaust system, lift it and put bigger tires on it (31's look tiny on this thing). Also I still haven't a F%*#ing clue about how to fix my gear display. It still says I'm in park at all times. I really don't want to replace my entire instrument panel.
1 - 1 of 1 Posts
