1 - 13 of 13 Posts
Just like the title says, used 1821 locker for an 8.8. Fits trucks until 86 and mustangs until 98. Was told it fits in some rangers too.
Gonna sell it at a loss, doesnt fit my truck and it's just sitting. $140 shipped via USPS.
Does this install in an open carrier???
If so I've got one, with carrier bearings on it that I'd make a deal on...It's the small cross pin style which I believe you need for that locker.
ford freak
oops, my bad. didn't realize it was the small pin. not gonna work for me.
That is something that can be confirmed by the original seller but it makes sense to me because I was under the impression the Rangers used the smaller pin.
Some rangers used the small pin 8.8 31 spline some some used the 28 spline. And yes, this is an open carrier install.
Is this a 3/4" or 7/8" cross pin Lock Right?
Urban Assault Bronco
how do i know what size pin i have? i have a 1992 econoline 150 if that helps
unless someone you trust can tell you for sure, you will have to pull the cover and measure the pin.
I would guess it's the same as the truck axles though, and is the larger pin
Discussion Starter #13
Rec'd, sending tomorrow!
1 - 13 of 13 Posts
