Chuck said:
Nice, thick gumbo mud. :thumbup
I'm already pretty familiar with the benefits of getting the timing set as close to ideal as possible, and I definitely agree it makes a bigger difference than just about anything else you can do. I was just curious where those numbers were coming from and what you recommended for testing and setting cruise timing. Curving the mechanical advance for full throttle is pretty easy if you're willing to spend a little dyno time, but finding the best vacuum advance curve under part throttle cruise for economy takes more than a little more work, so whenever I find someone with good info on the subject, I always hit 'em up for whatever I can find out. :rockon
How are you measuring for best cruise advance? Are you looking for the total advance that yields highest vacuum at cruise conditions, and then setting the vacuum advance canister to yield that advance at that vacuum? (Sounds circular, but I'm sure you know what I mean -- sort of an iterative process to find a setting that will give you highest possible cruise vacuum.) In other words, when you say one Mopar liked 57 degrees total timing at cruise, what are you watching to determine that it's running better on 57 than 55?
Right now I'm running TFI, so no vacuum canister for me, but I'm hoping to switch the truck over to Megasquirt sometime over the next year -- which would give me full control of all timing parameters. :thumbup
Chuck
Like you say figuring out mechanical full advance is fairly easy. Yes a dyno is the best, but most vehicles have people who've done it already and can get you in the ballpark.
A starting point for vacuum at cruise readings might well be the stock system. I know zero about megasquirt to I'll stick to the method for vacuum advanced carbs and you can extrapolate it into/onto your set up.
We were told 45-48 was a starting point for Mopars for full timing all in, including the added vacuum advance. This was borne out by taking the engine up to 2600 and reading the timing when the mitymac was supplying the same vacuum to the cannister that my car would at cruise (in my case 4 or 6 lbs{can't remember which})
Then I could take the 47 degrees (that it had) and subtract the mechanical advance (32 in my case) and that left me 15 degrees that the cannister was adding in.
Luckily Mopar used dozens of different vacuum cannisters through the 70s to allow for the different weights and gearing of so many different cars. Every one of them had a number stamped on the vacuum arm that goes into the dist. If it said 7.5 it was really 15 degrees that it would add in.
Using the excellent 70s Mopar service manuals and the Echlin and Standard catalogs I found a cannister that would get me above 52 degrees. Think it cost under $15 new.
Remember that it's going to give you 52 degrees at cruise regardless. What you need to set is what amount of lbs of vacuum your actual vehicle needs at cruise so it won't detonate.
What you're doing by driving your car/truck on the test drive at a cruising speed and rpm, in final high gear with a vacuum gauge, is determining how many lbs of vacuum it will exert on the cannister to activate the vacuum advance at the right time/lbs. In this low-tech way your particular engine, in your exact vehicle is actually stating exactly when it needs the vacuum all in.
Too much or too little lbs of vacuum and that's when you ain't gonna get away with 52 or 57 degrees total timing, and you throw up your hands like some Chevy ape and say "it doesn't work I'm-a-gonna tear off the vacuum cannister !" , kissing your mileage good-bye.
Honestly it took me several tries to understand the procedure, but if you follow it to the letter until you've got it straight in your head, it works everytime with every vehicle.
In answer to your question, what am I watching, you're listening and watching for detonation. I had zero rattle at 47 total timing, meaning I wasn't getting my money's worth out of the gasoline I was using. I jacked her to 52, changed cannisters and then 55 and finally 57 on one vehicle, as I'd backed her down from 60 which was rattling.
I guess what I'm saying is the alan key adjustment is adjusting "when" and at what vacuum {actual engine demand} the diaphram inside the canister is delivering the full amount of degrees. That's what determines if it's gonna rattle or give you mind blowing mileage.
Adjusting the alan key will not change the amount of degrees that cannister gives you, just tailor it to suit your vehicle's weight, gearing, gas grade, torque and power. Whoever thought it up was a genius in my books.
That said, I don't miss any of this with the computer in my early EFI'd 86 5.0 litre doing a much better job of all that and more IMO.
In future years I would like to MAF the truck and my 90 Lincoln in preparation for 351s and/or 393s or 408s.
Sixlitre
