1 - 3 of 3 Posts
I have a hissing sound coming from my drivers side floor board/firewall. I hit the search button, and the search button giveth. I assumed that the answer is replacing my brake booster. Seems like a fairly easy fix, and well worth the time and money.
I read that most of the people with faulty brake boosters heard a hiss when they pressed the brake. My hiss actually goes away when I press the brake, and stopping has not been an issue at all. The search button taketh away.
Before I start throwing parts at the problem, are there any suggestions to troubleshoot this? I've read the sticky on silicone vacuum line replacement, and that also appears to be a minimal investment. Is my 84' well overdue for a total vacuum line replacement?
yo izzie,
I ASSume it way past the vac hose service life; so I would change them all incl for the HVAC sys inside cab and in eng bay.
A Vacuum Gauge is a VG tool to use for troubleshooting as well as helping to see how much fuel you can save by not lead footing.
Here is my Vac Leak Testing, etc.
http://fullsizebronco.com/forum/showthread.php?t=206824&highlight=Vacuum+Leak+Test;+idling
post #11
pic; "...I have a vacuum gauge mounted right in the dash of my truck. I use it to also help determine the load my engine is under while driving, and to estimate fuel economy..."
by William T at
http://www.fordf150.net/images/mytruck/vacgauge.jpg
Your post was very informative. It seems like changing the lines is a good plan of attack. Whether it fixes this problem or not, it's still a good idea. I'll re-address once I get some new lines installed.
1 - 3 of 3 Posts
