1 - 4 of 4 Posts
Just got a edelbrock performer intake manifold installed on my '86 351W. I gutted the emissions system and just need the basic vacuum lines ran when i get a chance. So far i know i need the vacuum advance line from the carb to the dist. So my question is where do i need to run my brake booster line and my line coming from the firewall for a/c controls.
ac controls and brake booster need full intake vacuum. so any port off of the intake runner will do.
yo
EMISSION VACUUM Diagram in a 85-86 351W Carbureted
by Chilton
acronyms (not nec. for your year/engine)
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACV: Air Control Valve
AIR: Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: AIR BPV is the AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CPRV: Canister Purge Valve
CBD: Closed Bowl Distributor
DIST: Distributor
DV-TW = Two Way Delay Valve
EGR: Exhaust Gas Recirculation
EFCA: Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
FLTR: Filter
FPR: Fuel Pressure Regulator
HEAT VLV INT = Heat Vacuum Control Valve Intake, (next to carb)
HICV = Hot Idle Control Valve
IVV: Thermactor Idle Vacuum Valve
LCV = EGR Load Control (WOT =Wide Open Throttle) Valve)
MAN VAC: Manifold vacuum-Vacuum source
MAP: Manifold Absolute Pressure; near AC/Ventilation Systems Vacuum Tank (black plastic ball type) see pic below by Steve83
PURGE: Vapor Canister Purge Valve
PV: Ported Vacuum
PVS: Ported Vacuum Switch (PVS) Valve
PCV - Positive Crankcase Ventilation
SA-FV - Separator Assembly Fuel/Vacuum
SOL V: Thermactor Air Diverter (TAD) Solenoid (SOL V) (AIRD) & Thermactor Air Bypass (TAB) Solenoid) in mid 80's, passenger) near AC/Ventilation Systems Vacuum Tank (black plastic ball type) see pic below by Steve83
SV-CBV: Carburetor Fuel Bowl Solenoid Vent Valve
TCP: Temperature Compensated Accelerator Pump
VAC: Vacuum
VCKV: Vacuum Check Valve
VRESER: Vacuum Reservoir (Tank) in mid 80's, passenger) near AC/Ventilation Systems Vacuum Tank (black plastic ball type) by Steve83
V REST on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time
VCV - Vacuum Control Valve
VRV: Vacuum Regulator Valve
V CK V: Vacuum Check Valve
VOTM - Vacuum Operated Throttle Modulator
VRDV: Distributor Retard Delay Valve
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
or
TVS: Temperature Vacuum Switch
TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches)
VRDV = Vacuum Delay Valve (VDV, VRDV, DV-TW)
VDV = Vacuum Delay Valve
See my site for info on most of the above
EMISSION; http://www.broncolinks.com/index.php?index=24
Carburetor; http://www.broncolinks.com/index.php?index=204
There should have been a little vacuum tree type thing at the back of your old intake for the brake booster and other full manifold items. It should be the same for the new intake. There will only be one port big enough for the brake booster line anyway.
1 - 4 of 4 Posts
