1 - 3 of 3 Posts
1986 Ford Bronco, 351w with edelbrock aluminum top end and holly 600.
Howdy - anyone know why I couldn’t use the vapor return line for a fuel return line to the tank? What is on the tank side? Filter? Check valve?
I believe the valve at the top of the tank is a check valve. I think I've heard it referred to as a rollover valve. Other than that, I think the vent line is too small in diameter as well. Are you adding EFI?
Addicted to Junk
Too small and not rated for pressure. Being so small, the incoming pressure would rise as it entered the small tube.
Id just run a new line
1 - 3 of 3 Posts
