After some fun off-roading, next up was the axles. We put in a Detroit Locker in the rear and a Detroit TruTrac (worm gear LSD) in the front with some 4.56 gears to match.
That was a good decision. :rockon
This thing felt unstoppable and it was so far with everything I have thrown at it. I am not gentle with my vehicles and this was no exception.
It was awesome. It just could not go up a hill on the freeway above 35mph but other than that it WAS AWESOME. :toothless
It didn't take long before the Bronco was only running on 6 cyl and of course would not pass smog. The compression was down and it was time.
Earlier, I had picked up up a 302 roller longblock with GT40 heads, recently rebuilt for $500. It was from an Interceptor (I was told).
Anywho, I had never rebuilt, installed or done any engine work at all because I was terrified at the thought of it. But, I had the block in the garage and was slowly learning and building. However, when the Bronco's engine bit the dust, I had to kick it into overdrive.
Pulled the stock engine and sold the long block for $200 (If I remember correctly). I then learned the difference between flat tapped and roller. :duh
My plans of reusing the Bronco cam went out the window. Luckily, the 302 roller came with a F cam in the block and a X cam on the side. So, I sold the two cams and used the money to pick-up a new cam from COMP (off-road specific).
I put it all together, threw on some tube headers from Summit and painted a few things. Never did get around to taking pictures once the engine got installed. Will do later.
Once in, the bugs were worked out and it roared to life. I did not realize my big ass Bronco could move like that :toothless
Got a one day pass to drive it over to my friends dyno shop to get it on the rollers and see how the smog numbers looked before taking it in.
Long story short, the transmission grenaded and it was down again.
After spending so much time doing the engine, I didn't have it in me to pull it back into the garage and try the transmission. So, I had a good shop rebuild it will all HD internals, shift kit, TQ converter and whatever else. (One of the very few things that I paid a shop to do).
When it was all said and done, it passed smog and felt great.
We took it to Johnson Valley to watch KOTH (4 hours away) without a single problem.
Good times.
More to come later.
