A9L93 E40D + 10.25 = :thumbup
What computer are you wanting to run?
Yes the 92 up spedos are PSOM
But youll need a rear axle with a tone ring to run one.
It will work for that computer and your existing speedo, but I belive the number of pulses per tire rotation would be diferant from an axle mounted VSS. This would make the PSOM be way off.A9L
So they won't work if you put the vss in the t-case whre the speedo cable went?
It can any of those years with a t-case mounted VSS. Carbed models with cruise had them also.ah, ok. So ill just find me a vss from an 85 0r 86 or so EFI truck and the speedo cable to match. Doesn't seem too difficult then lol. Wonder if advance has them new....
...does that mean i can't use a t-case mounted vss for my EFI?Pre~'85 used a cable-mounted VSS (6 pulses per cable rev) for cruise only.
~'85-91 used a t-case mounted VSS (6 pulses per cable rev) for cruise and E4OD shifting. The ABS sensor was only used for RABS. The ESOF t-case always had its own dedicated speed sensor in the tailhousing.
'92-96 use the ABS sensor (108 pulses per diff rev) in the rear axle (via the ABS module) to feed the PSOM, which then feeds everything else.
That's still my advice.Steve83 said:B) The only thing the EEC needs a VSS for is to manage an electronic automatic, like an E4OD or 4R70W, so: no, you don't need it.
