i searched and read through some threads but couldnt find an answer. ive read that a truck needing VSS would shift bad if you dont have it. what year axles can i use in my 95? ive read from 87-96 because the 91s and below with ABS had the same tone ring and sensor. im just lookin for years i can use.
You can use any Ford 8.8 or Sterling 10.25 that has an ABS/VSS sensor on the top of it.
thanks. im lookin at an 89. it should have the sensor but we'll see. now can anyone tell me the easiest way to hook up the e-brake?
An 89 Ford 8.8 out of a truck will have an ABS sensor on it.
Get the whole e-brake cable setup from the truck to where it splits I think.
i told the guy to pull the rear out. he'll probly cut the e-brake cable though. i should be able to figure it out, but i know its a pain in the ass.
Ah, it's not that bad.
Steve83's supermotors comes in real handy when playing with the drums.
