Building gold from crap
is a hub meant for a dana 44 going to work on any dana 44
so if it was a 5 lug 1/2 ton axle, is the same hub going to work on a 3/4 ton 8 lug dana 44?
Warn Premium 4WD Hubs
PREMIUM MANUAL HUBS
The Warn Premium Hub is a no-compromise hub designed for the hardcore off-roader or truck owner who will accept nothing less than the industry standard in performance. The all metal construction and ZA Alloy dial ensure years of reliable functioning. This dial requires a full 9/10ths of a turn to ensure positive engagement of the inner drive gear to the clutch ring. To make sure they stay engaged, Warn premium hubs use a thick internal wave spring and heavy dial detents. We know our premium hubs will be used hard, so we build them to last. We're so confident all
Warn hubs are covered by a lifetime limited warranty.
All Warn Premium Hubs feature:
- 9/10 turn dial for robust engagement/disengagement
- Heavy detents for positive engagement
- Wave spring technology increases reliability over standard coil springs.
- All metal construction
- ZA Alloy dial with dual seals keep contaminants out
Warn Premium Manual Hubs
Warn WAR.20990 Hubs, Fit all the Follwing Applications:
GM Blazer, Jimmy, Suburban 69-91 (without full time 4wd)
GM 1/2 Truck 69-87
GM 3/4 ton Truck 77-87
Dodge 1/2 ton Truck & Ram Charger 69-74
Dodge 1/2-3/4 ton Truck & Ram Charger 80-93
Ford Bronco 66-96
Ford 1/2 ton Truck 59-96
Ford 3/4 ton Truck Light duty 77 1/2-97
International Harvester 1/2 ton Truck & travelall 68-75
Jeep J10 Truck Commander 74-91
Jeep J20 Truck 77-87.
Looks like a winner :shrug
cool beans, that is what i thought, which is why i kept them, but i just had a bad feeling they wont work on the f250 im hopefully getting
as long as you have the ligther duty f250 that 77.5 or newer they will work fine. i ran them on my trucks front axle usiogn outers from a 79 F250 before i got the d60.
