Warning Buzzer after turning Bronc off...
7175 Views 23 Replies 7 Participants Last post by  miesk5
It's not the door chime, already took that little module out. I get a warning buzzer which beeps loudly when I turn the engine off. This happend about a year ago which was only due to my air bag light burning out. It did it a year ago after I turn the engine ON though, now it's the opposite and the air bag light is fine.....
BUT WHY?
I see or hear no problems. Any idea where this little buzzer thing is so I can just remove it? Thanks
:thumbup
1 - 20 of 24 Posts
for one, it sounds aftermarket... I've never ever heard my truck buzz..... Only the stock 90's chime
Well, it's not a buzz, that's my fault for calling it that. It's a loud ding, 5 in a row. It's not aftermarket either. I found info about it in my manual. The only info I could find is that it goes off when the air bag light has failed, though, which it hasn't this time.
maybe a sensor failed
I hope not or my truck is going to Beep loudly every 45min or so over and over until it's fired up
yo D;
I know you wrote "The only info I could find is that it goes off when the air bag light has failed, though, which it hasn't this time."
So, for my cloudy Mon mrong mind,
does the Air Bag lamp in instr cluster flash for approximately six seconds when the key is in RUN?
I took my dash out and reinstalled it now I've got some annoying ding like this as well. Never heard it before - where in the manual did it talk about that? I've got to remove whatever it is, or jamb a screwdriver through it's speaker - I don't care about airbags :p
how about a video?
have you checked to make sure its not an aftermarket radio?
yo D;
Actually, the airbag light will randomnly flas while I'm driving. It is not suppose to beep loudly though as long as the bulb isn't burned out.
I can't remember , but I'll look it up again. It was somewhere small and not noticeable. I think it was in the section about the intrument panel. I would love to find where the speaker is and cut the damn wires. I already took out the door chime module...
how about a video?
Not a bad idea... I got a buddy with a nice camcorder. I'll try to borrow it soon and post it.
There's is an aftermarket Alpine in it, which i installed about a year and a half ago. It's not the radio though, I know that thing back to front and I havn't had any wiring issues I'm aware of recently either.
yo D,
re; the airbag light will randomnly flas while I'm driving.
Testing, Wiring Diagram, Operation & Troubleshooting for 94-96 by Ford via Steve83 (Steve, That dirty old truck) at SuperMotors.net
The air bag diagnostic monitor (14B056) continually monitors all supplemental air bag restraint system components and wiring connections for possible faults in the system. If the air bag diagnostic monitor detects a fault in the supplemental air bag restraint system when the key is in RUN, a diagnostic trouble code will be displayed on the air bag indicator, located in the instrument cluster (10849). Performing system diagnostics is the main purpose of the air bag diagnostic monitor.
Note: The air bag diagnostic monitor does not deploy the air bag in the event of a crash.
The LH and RH primary crash sensors are hard wired to the air bag; therefore, the LH and RH primary crash sensors and RH safing sensor and bracket sensor determine when to deploy the air bag.
Features and functions of the air bag diagnostic monitor are described below.
* The air bag diagnostic monitor illuminates the air bag indicator for approximately six seconds when the key is in RUN and then turns the indicator off. This shows that the air bag indicator is operational. If the air bag indicator does not illuminate or the indicator stays on or flashes at any time, a fault has been detected by the air bag diagnostic monitor.
* Diagnostic trouble codes may not be displayed for approximately 30 seconds after the key is placed in RUN. This is the amount of time the air bag diagnostic monitor requires to perform all tests and verify system faults, if present.
* Each diagnostic trouble code (a series of flashes and pauses of the air bag indicator) represents a two-digit number. Each diagnostic trouble code is always displayed at least twice. For example, a diagnostic trouble code 32 is displayed as three flashes, followed by a one-second pause, then two flashes, followed by a three-second pause.
* If a system fault is present and the air bag indicator is malfunctioning, an audible tone will be heard, indicating that system service is required. The tone is a series of five sets of five beeps. This does not indicate a diagnostic trouble code 55. If the tone is heard, the air bag indicator is inoperative and a system fault that requires service is present.
CAUTION: The thermal fuse does not blow (open) because of excessive current flowing through it. DO NOT attempt to jumper out the thermal fuse with a circuit breaker or any other type of fuse.
* If a fault exists that makes unwanted air bag deployment possible, the air bag diagnostic monitor has an internal thermal fuse that will blow (open) automatically. This removes all power to the air bag deployment circuit.
* The air bag indicator will flash the appropriate diagnostic trouble code to indicate the suspect circuit. If the indicator is malfunctioning the tone will be heard. * Diagnostic trouble codes are prioritized numerically so if two or more different faults occur at the same time, the fault having the highest priority will be displayed first. After that fault has been corrected, the next highest priority fault will be displayed.
* The air bag diagnostic monitor includes an internal backup power supply. This feature provides sufficient backup power to deploy the air bag in the event the battery or battery cables are damaged in an accident before safing and primary crash sensors close. The backup power supply will deplete its stored energy approximately one minute after the positive battery cable is disconnected.
Airbag DIagnostic Monitor (ADM) Light Flash Code (LFC) Priority Table
Tone (5 Beeps Repeated 4 Times): Air Bag Indicator Open Circuit with Stored Fault Code(s)
No Air Bag Indicator (Dash Light Out): Inoperative Indicator Circuit or No Battery Voltage to ADM
Continuous Air Bag Indicator: ADM Disconnected or Inoperative
12: Low Battery Voltage
13: Air Bag Circuit Shorted to Ground
14: Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21: Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22: Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23: Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24: Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32: Driver Side Air Bag Circuit High Resistance or Open
34: Driver Side Air Bag Circuit Low Resistance or Shorted
41: RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42: LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44: RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45: LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51: ADM Internal Thermal Fuse Blown Due to Intermittent Short to Ground
52: Backup Power Supply Voltage Boost Fault
53: Front Air Bag Sensor and Bracket Circuits Resistance to Ground or ADM Fault
Rapid Continuous Flashing of Air Bag Indicator (No Fault Code): All Primary Air Bag Sensors Disconnected
Next up to bat is from my 96's Owner's Guide;"...
How the Air Bag Supplemental Restraint System Operates
The air bag supplemental restraint system has two main parts. One part is the air bag system with the driver air bag and inflator located in the center of the steering wheel. The second part is the electrical system, which has impact sensors, and a diagnostic module, and backup power supply. The diagnostic module monitors its own internal circuits and the supplemental air
bag electrical system readiness, including the impact sensors, the system wiring, the air bag system readiness light, air bag power, and the air bag ignitor.
The air bag system uses a readiness light and a tone to indicate the condition of the system. The readiness light is in the instrument cluster. When you turn the ignition to the ON position, this light will illuminate for approximately six (6) seconds and then turn off. This indicates that the
system is operating normally. NOTE: Maintenance of the air bag system is not
required.
A problem with the system is indicated by one or more of the following: the readiness light will either flash or stay lit, or it will not light, or a
group of five beeps will be heard.
Damn you have useful information... thanks man. So, basically speaking I have a malfunction of some kind involving the airbag. Not a surprise... I wonder how I make it quit though........:rofl:
yo D,
required.
yo,
ty, but thnx also goes to Ford for making avail. that info and others such as Steve83 for posting it.
Count the air bag lamp flashes;
I have some Troubleshooting links for the common codes in my site @ http://www.broncolinks.com/index.php?index=109
The $60,000 question is:
Where is the speaker?
:banghead
2
yo,
Air Bag Module, Remote Keyless Entry Module and Radio Amplifier and Wiring
Item Part Number Description
1 N803876-S36B Screw
2 15K602 Remote Keyless Entry Module
3 18B860 Premium Sound Amplifier Bracket
4 — Bracket for Chime Module (Part of 10D840)
5 14B058 Remote Keyless Entry/Air Bag Bracket
6 04320 Instrument Panel
7 14401 Wire Assembly
8 19B113 Wire Assembly
9 — R.K.E. Antenna (Part of 14401)
10 14588 Wire Assembly
11 18B849 Premium Sound Amplifier
12 14B155 Cap (Vehicles with Automatic Transmission and Premium Sound)
13 — Locator, Position in Hole Provided (Part of 14401)
14 14A594 Retainer Assembly (F-Series Gas with Remote Keyless Entry System and/or Shift on the Fly Without Air Bag)
15 14B056 Air Bag Module
16 — Remote Keyless Entry Programming Connector (Part of 14401)
17 14A163 Retainer, Wiring Harness
A — Tighten to 2-3 Nm (18-27 Lb-In)
----ok, so now we need to find this where this is exactly behind Instr Panel/Dash
Instrument Panel Wiring Installation, F-150, F-250, F-350 and Bronco (Gasoline Engines)
1 — To Headlamp Switch
2 — To Fuse Box
3 14A282 Retainer Assembly
4 N606678-S39 Screw
5 — Connector (Part of 12A581)
6 — Connector (Part of 14A504)
7 13A506 Locator, Position in Hole Provided
8 — To Park Signal Lamp Switch
9 — To Multi-Function Switch
10 — To Stoplight Switch
11 — Clip (Part of 14401)
12 — E4OD Pigtail (Part of 14401)
13 — To Ignition Switch and Steering Column Wiring
14 — To 14405
15 — To Starter Switch Clutch Interlock
16 — Take-Out to Shift on the Fly Switch and Electric Defrost Switch (Part of 14401)
17 — To Warning Buzzer Chime
18 — Remote Keyless Entry Programming Connector
19 15K602 Remote Keyless Entry Module
20 — Air Bag Module
21 14A163 Retainer Assembly
22 — To Trailer Brake Controller
23 14A099 Shield
24 — Vacuum Hose Clip (Part of Vacuum Harness)
25 — Ashtray Wiring (Part of 13726)
26 15A044 Cigar Lighter
27 — PSOM Test Circuit (Part of 14401)
28 — To Bowden Cable
29 18813 Radio Antenna
30 — Brake Anti-Lock Module Test Circuit (Part of 14401)
31 — To 14630
32 — To 14B095
33 — To 18A586
34 — To Right Courtesy Lamp Switch
35 — To Inertia Switch
36 14463 To Ground
37 — To Clearance Lamp F-Series Only for Continuation
38 — Wiper Control Module
39 2C018 Rear Brake Anti-Lock Module (F-150, F-250, F-350 Only)
40 — To Glove Box Lamp
41 — To Heater Mode Switch
42 — To A/C Illumination
43 — To A/C Blower Switch
44 — To Power Point
45 — To Radio
46 18B849 Premium Sound Amplifier
47 14B166 Shift on the Fly Switch
48 — To 14A262 Electric Defrost (Bronco Only)
49 14401 Wiring Assembly
50 — To Cluster (Plug A)
51 — To PSOM
52 — To Cluster (Plug B)
53 14B155 Cap
54 04320 Instrument Panel
55 9A050 Dual Fuel Tank Switch (F-Series Only)
56 14529 Rear Window Control Switch (Bronco Only)
57 — Demister Hose
58 — To Glove Box Lamp
yo,
This didn't make it in above, for some reason... maybe because I haven't hit the rack in 36 hrs?
Views are from Front; so driver's side is on Right
The Airbag Diagnostic Module (ADM) is light blue, wrapped in black foam, above the gas pedal..." as written once here by Steve83
yo,
No problem and thanks man. I'll try to check it out and see what I can figure out...
1 - 20 of 24 Posts
