1 - 9 of 9 Posts
Teddy Bear
like the title say, or should i swap bell housings and put the e4od from this 93 in my 86, or can an 86 aod(if thats what it is) be run by a e4od ecm(brain box)
E4OD wasnt avalable in 86. The AOD is not computer controlled..The E4OD ECM should do fine, but it will toss some transmission codes(That dont effect the engine AFAIK)
why would u want the e40d in an 86? not understanding that?
Teddy Bear
well im about to do a body swap along with harness, and my truck is an 86 and all of this stuff is coming froma 93 and i cant find an AOD brainbox so i was just wondeing
ah i got ya, if the aod is not computer controlled, like the previous post says, than maybe a manual or c6 brainbox would work in its place, i am under that impression but i could be wrong, im sure someone will chime in w/ the answer,
as long as it is for w/ motor u have, v8=v8, I6=16
i thought u had to change the pcm?
Teddy Bear
steve is a 93 an eec, or if i flip bodys, harnesses, and pulg in a 5.0 brain box i can start the truck up and go
1 - 9 of 9 Posts
