1 - 17 of 17 Posts
so i went and picked up my AOD from the junk yard. didnt get the transfer case because i saw a huge crack in it and decided that since i didnt need it in the first place not to even bother. but i got the tranny. its dirty as all heck with sand and whatnot on it. can i just spray it down with a hose or what is the best way to get all the dirt and grime off of it. i know its going to get dirty once its in again but i dont want dirt and whatnot falling while trying to put her in.
Roller rockers are gay
pressure-washer, if ya don't have one, i'm sure home depot, or sears or something will rent one. you can also buy soap solution that you can attach to the pressure washer that will go through the hose. nothing better than pressurized soap. :thumbup
awesome! yea il borrow my dads pressure washer. :)
Practicing Infidel
Or schlep it down to the coin wash
in the back of a friends pick up
Why should your garage get messy when the car wash can get messy ? You can pre-spray the outside with a degreaser first to soak(15 minutes), much like Spray n' Wash.
Sixlitre
Satyr of the Midwest
:stupid
...and MAKE SURE you plug BOTH of the open cooler lines!!! Get some pipe plugs from a hardware store, or if they have pieces of the old lines left on the transmission, bend/pinch them off. You don't want that soap and hot water inside the transmission, and I'm absolutely sure you don't want to have to go through this again. Try to keep the spray away from the front pump's input shafts-area, too.
Sixlitre
didn't even think of that. :doh0715:
Practicing Infidel
That's cause yer honest and law abiding Stepchild
Age and Treachery will overcome Youth and Enthusiasim everytime;)
Sixlitre
p.s./
I've redcorated many a local coin wash :toothless
thats a wonderful idea except.......
ihave no clue where a coin wash would be around me and i dont have any friends with a truck. we all sold our trucks when kids came on the scene. heehee made corey sell his bronco 2 because it had no air. heehee. ill just bring the pressure washer here to work and do it here. heehee THANKS YALL!
Practicing Infidel
Don't forget to pre-soak the exterior with a de-greaser
BTW I trust you're going to install a trans cooler and remote filter for this next AOD ?
Sixlitre
Former owner of Shadofax
Sixlitre
p.s./
Plus you're a crazy Canadian.:toothless
what the heck were you guys thinking beating our baseball team? stick to hockey.:doh0715: :twak
Sixlitre
p.s./
i dunno Six, i've left plenty poundage of mud in my local gas station's coin wash bays in my day.
Discussion Starter #13
Sixlitre
ummmm.....talk stupid to me....a what? if its needed and you tell me what it is how much it costs and where to get it then yea i will.
Practicing Infidel
shibby
SigEpBlue said:
:stupid
Plug both cooler lines as mentioned and also plug the dipstick hole very well and the breather vent at the top of the case as well. It would be an excellent idea to drop the pan and let everything drain after you've finished washing it.
1 - 17 of 17 Posts
