1 - 2 of 2 Posts
Ok so I hit a cow in my bronc in december. So I took the money insurance gave me to go ahead and do a leaf sprung d60 swap in it. well one of the other problems was I had a blown water pump so I replaced that yesterday. But I then started to fill it up with coolant and there is a worse leak than the previous blown one. It is leaking on the drivers side behind where the big tube goes to the radiator. I have double checked to make sure all the bolts are tight and all but it still leaks. I used the right stuff gasket sealer when putting it on and everything. So have any of you guys had this problem?
CODY
Lick my balls
Did you remove all of the old gasket? If yes than did you use any type of gasket glue? Finally maybe the gasket shifted on you.
1 - 2 of 2 Posts
