1 - 9 of 9 Posts
1992 Ford F150 5.0 2WD
All bolts go in normally except the one that goes with the bracket. I can't remember, does the bolt go before or after the bracket? When I try to install the bolt I have to force it in quite a bit and think paste substance come out of the block area.
I didn't but when reinstalled it used a new bolt and it worked fine. I confused my self and removed it after, then on reinstall the 2nd time is when it didn't work. I don't think my tap can go that deep but I'll give it a shot. Thanks, I hope that does it.
Yo Abraham,
From
Section 03-01B: Engine, 5.0L and 5.8L MFI
1996 F-150, F-250, F-350 and Bronco Vehicles Equipped with 5.0L or 5.8L MFI Engines Workshop Manual​
IN-VEHICLE SERVICE
Water Pump
Removal
  1. Drain the cooling system. Refer to Section 03-03.
  1. Remove drive belt (8620).
  1. Loosen the bolts on the fan clutch (8A616).
  1. Remove the bolts securing the fan shroud (8146) to the radiator (8005). Remove the fan shroud.
  1. Disconnect the lower radiator hose (8286), heater water hose (18472) and water bypass tube (8548) at the water pump (8501). Remove water pump pulley (8509).
  1. Remove power steering and A/C bracket bolts and position bracket out of way.
  1. Remove water pump attaching bolts and remove water pump from engine (6007).
Installation
  1. CAUTION: Do not use solutions such as brake cleaner, carburetor cleaner, etc., as these solutions can leave a residue on the machined surfaces. Use only a cleaner which meets or exceeds Ford specification WSE-M5B392-A, such as Metal Surface Cleaner F4AZ-19A536-RA or equivalent.
    NOTE: Before a water pump is installed, check it for damage. If it is damaged, replace it.
    Remove all gasket material from the mounting surfaces of the engine front cover (6019) and water pump.
  1. Position a new gasket, coated on both sides with Ford Perfect Seal Sealing Compound F2AZ-19554-AA or equivalent meeting Ford specification ESE-M4G115-A or ESR-M18P2-A, on the engine front cover; then install the water pump.
  1. Install the attaching bolts. Tighten bolts to 20-28 Nm (15-21 lb-ft).
  1. Install the fan shroud, lower radiator hose, heater water hose and water bypass tube. Tighten clamps to 3-4 Nm (27-35 lb-in).
  1. 👉Reposition power steering and A/C bracket. Install power steering and A/C bracket bolts. Tighten bolts securely.
  1. Position water pump pulley on hub.
  1. Install the fan blade (8600) and fan shroud assembly to the water pump pulley. Install and tighten bolts to 16-24 Nm (12-18 lb-ft).
  1. Install the drive belt. Refer to routing decal.
  1. Fill and bleed the cooling system. Refer to Section 03-03. Operate the engine until normal operating temperatures have been reached and check for leaks.
Thank you. Is there a nut that holds the bracket onto the water pump bolt? I didn't take as good pictures as I should have on removal.
Yo Abraham,
Ford didn't bother to include their usual parts break-out diagram.
Here.
1 - 9 of 9 Posts
