41 - 58 of 58 Posts
1979 Custom, 6.6L Auto
Discussion Starter · #41 ·
Got tired of polishing chrome and moved into the interior flooring that I am trying to save. The front rubber floor is original but had a few cracks/tears from getting hard and shrinking from age. There was a small amount of surface rust on the drivers but the passenger side had more signifigant rust and a couple small holes.. Poked around with an ice pick to find the thin areas and then broke out the thin areas. Then used navel jelly, then rust paint, then patched any holes with welder, primed, covered patches with seam sealer, then final coat of paint. Would have been better IMO to replace a floor section on the pass side but trying to keep as much original as possible.
Drivers after navel jelly.
Navel jelly working and small holes.
Patched.
Seam sealer over primed patches, another coat of paint was applied over this, before the jute padding was installed.
Discussion Starter · #42 ·
The OEM style rubber flooring seems to be a rarity so decided try and restore the original.
Several steps and many hours later.. looks like it can be saved! Was about a 12" tear where the hump and pass floor meet..
New padding installed on floor areas that were deteriorated, and re-using original padding for the hump area.
So much better!
Discussion Starter · #43 ·
This was the closest replacement for OEM that I could find (vinyl), so available if needed for resto.
You may be better off doing a repaint on that hood and roof. I have a truck with similar mileage that I need to do the same to. Even a cheap single stage properly taped off would preserve the steel.
Discussion Starter · #45 ·
Agreed, paint would definately be a good choice with something so weathered. But problem was, would either have to fake patina the new painted areas to match, or paint the whole rig.. and I liked the idea of keeping it origional. Guessing the coating on there should be about the same effect as paint, keeping out the air and moisture yet still a paintable surface when it comes time for a re-paint. Wasn't trying to get rid of all the rust on the hood/roof, just to stabilize it and wanted to keep the original character.. hence no rust converter used in those areas. The rust kinda matches the faded Dark Brown Metallic lol
Discussion Starter · #46 · (Edited)
Restored vs original rubber floors and moving to the rear. (After scrubbing with degreaser, then soaked with 303 brand protectant for 24hrs.)
Rear padding was in good shape and found some Michigan plant swag underneath!
Fairly clean under the padding with just a little surface rust on drivers side. Cleaned up pretty good. Going to put a coat of rust converter paint on the left side before covering up.
Discussion Starter · #47 ·
More of the chalked "54" showing up in various places..
and peaked my interest so I checked the build sheet looking for a "54" and find the "ROTATION NUMBER" at upper left is 1654..
I remember seeing that somewhere... oh yeah, inside the passenger side fender with a big S lol!
So guessing the 54 tagged all over this Bronco is reference to the rotation number.. Who knows? Or maybe more accurately, who cares! lol Just interesting going through this unmolested stocker. Don't think this is what they mean by "numbers matching" but they do! lol
Discussion Starter · #48 ·
Had some nice weather so cleaned up the rear frame and fenderwell areas before winter hits. With all the weathered steel I been cleaning lately it was nice to see the new brakes!
Discussion Starter · #49 ·
Rear flooring and side panels back together. Did not think the old rubber floors could be saved but so suprised looks almost new. The 303 softened it up a little as well so should last a few more years.
IMG_20201102_210601059.jpg IMG_20201102_224610602.jpg IMG_20201103_021409168.jpg IMG_20201103_021309500.jpg
Discussion Starter · #50 ·
Trim and rubber cleaned up pretty well and getting the mirrors back on woot woot!
For the trim, used this and a hand drill around 1000rpm. Red bar in kit seemed to work better of the 2. Was able to take off deposits and water spots no problem and didn't harm the paint if contact was made.
View attachment 170697 View attachment 170698
wow that paint is coming out great
Discussion Starter · #53 · (Edited)
I've been told to paint the bumpers, and that would be easy... and would look great.. so makes sense, but.. I don't like the idea of covering up the deterioration.. Weird. Guess I see it as more of an artifact to be preserved and examined rather than looking "new". With that being said, no repro parts on this Bronco and polished up the faded out bumper.
IMG_20201124_005952944.jpg IMG_20201123_234714180.jpg IMG_20201123_235232890.jpg
Discussion Starter · #55 ·
Steam cleaned the inside of the top, installed some interior trim, spare and jumpseat. Anyone know how to identify if this is an original spare, like a date code or??? TIA
Discussion Starter · #56 ·
Front seat is back in, and used the original upholstery. Hard to find anyone that would even attempt a preservation/repair job for the split seams, but got it stabilized with machine and hand stitching combined. Turned out pretty good given the age! Almost complete and to wrap back around to the initial post, super happy with the WAX choice, look at that shine! and thanks to those that steered me in that direction!
IMG_20201207_220355947_HDR.jpg IMG_20201209_015446791.jpg IMG_20201209_014921969_HDR.jpg IMG_20201210_084618992_HDR.jpg IMG_20201210_084641199_HDR.jpg IMG_20201210_084730966_HDR.jpg IMG_20201210_084757197_HDR.jpg
Discussion Starter · #58 ·
Back to this original spare question... Yes it is the original spare tire! But how do I know??
The build sheet shows this Bronco was rotation number "1654", and equipped with "M" mud & snow tires factory option.
Marti Report shows "7.00x15-D Black Sidewall Tires" and "Mud and Snow Tread Tires"
Was reading the General tire handout found in the glovebox, got curious, went out and looked at the spare with a flashlight and yep, was a General tire.. then I saw the faded white "1654".
Looked back at older pictures and the numbers on the spare were much more visible before I cleaned it!:ROFLMAO: but had no idea or care at the time that these numbers meant anything.
41 - 58 of 58 Posts
