yoTW,
You have an 88, correct?
See my site @
http://www.broncolinks.com/index.php?index=487 for many WS LINKS such as;
Parts Break-Out Diagrams in 78-96 w/Ford part numbers; 1978-96 D8TZ-9851322-A Removable Roof Front Seal On fiberglass roof; D8TZ-98513C22-PR Removable Roof Side Panel Seals on 78-79; D8TZ-9854732-A Front Roof Rear Seal on metal roof on 78-79; E1TZ-98422A20-A Back Window Glass Lower Side Run, RH or LH on 78-96
Source: by bwautoparts.com via web.archive.org & miesk5 at
http://fullsizebronco.com/forum/showthread.php?p=2206087&posted=1#post2206087
Tailgate Terminology & Sources in 78-79 & 80-96
Source: by miesk5 at
http://fullsizebronco.com/forum/showthread.php?t=183147
for other Topics, see my site for the HOT LINKs to others such as;
Tailgate Weather Strip Reviews; "...So I went with trusty ol' LMC. The weatherstripping came on the UPS truck about a half hour ago, and I spent the last 10 minutes putting it on. Beautiful, flawless....i bought my rubber from lmctruck.com and it was an exact fit no issues at all. I just did the upper in the cap of my 88 and got my rubber from Jeff's. It didn't require reusing the clips, just popped right in..."
Source: by loarmistead, Troy & generaltso at FSB
Window Regulators, Weatherstrip & Vent Parts Break-Out Diagram in 80-96
Tailgate Weather Seal Replacement; applies to all years for most
Lubrication
"...Use Silicone Lubricant C0AZ-19553-AA (jelly) and D7AZ-19553-AA (spray) or equivalent meeting Ford specification ESR-M13P4-A on the door and window weatherstrips whenever necessary. Silicone lubricant helps avoid weatherstrip squeaks and retards excess weatherstrip wear from chafing between the door glass upper frame and the weatherstrip. It also helps to retain door window alignment by reducing friction between the glass frame and the rubber weatherstrip. Use Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs..." miesk5 Note, test the silicone on a regular styrofoam cup first; if the cup gets funky or melts, then the can or tube contans oil, a regular occurrence now, esp if from China
Camper Top Location Diagram #1; "...There's 1 weatherstrip across the back of the cab that slips onto a lip of steel, and a reinforced rubber trim that covers another lip, but it doesn't seal anything. Then there's a foam rubber gasket glued under each side of the shell, terminating in a large foam block at the tailgate. So that's a total of 4 pieces, but only 3 are seals. Only the weatherstrip on the cab is marked in the 1st diagram, but all are shown in cross-section..."
Camper Top Location Diagram #2; "...There's 1 weatherstrip across the back of the cab that slips onto a lip of steel, and a reinforced rubber trim that covers another lip, but it doesn't seal anything. Then there's a foam rubber gasket glued under each side of the shell, terminating in a large foam block at the tailgate. So that's a total of 4 pieces, but only 3 are seals. Only the weatherstrip on the cab is marked in the 1st diagram, but all are shown in cross-section..."
Adhesive for Camper Top Front & Side Weatherstrips; "...They don't attach to the metal - they're glued to the fiberglass, with a few screws at the rear corners. The cream color is the paint off the fiberglass. 3M Super Weatherstrip Adhesive is probably the best for this application, but you MUST follow the directions to the letter - otherwise, it won't hold for $#!T..."
Source: by Steve83 (Steve, That dirty old truck) at FSB
