1 - 8 of 8 Posts
Ogeechee 4x4 said:
nice! I like your idea for the hi-lift. :thumbup What happened to your reunel (spelling?) bumper??
Me too
What year F550 is that shackle for? I was looking at some 2006 F550's and I could have sworn they had a slipper type mount
The base is made out of this
http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1613555356
This is what the bolts are screwed into
http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611768755
I got all my stuff from the Home Depot. I got the thickest stuff they had.
I bought the bolts from the same section.
I took the panel covering the window off put a piece of wood over the window and drilled the holes. Mount the bolts with the nut facing up and tightend. After I tightend everything up I took the cable off on the driver side holding the tailgate and slid the cover under the brackets. I used eyebolts because I can use a screw driver and tightend the piss out of it.
Discussion Starter · #8 ·
MikE2 said:
Me too
to make the shakle work I welded metal on the ends and drilled it out the match the size of the original sized bolt. I could not get the spacer in the middle of the spring pack to drill out to a 5/8" hole. Which is the size of the bolt hole on the new shackle. Just so you know. Im sure there are plenty of other ways to do it and I may get flamed for the way I did it, but it works for me.
1 - 8 of 8 Posts
