· MidlifeCrisisUndrWay
When I accelerate and just before coming to a complete stop, I feel weight shifting.
I want to say it feels like the engine/tranny shifting.
Could it be the TTB?
Ive been underneath and the drive train mounts 'appear' intact.
My Bronco is a '94 with over 190,000 miles on it.
Try This Cheap and Easy Fix
Try lubing the Slip Joint...it worked for me. I swore i had a broken tranny mount....took it to a mechanic, they said bad rear springs bushings...then i did a search on here....whoolaa...it was the slip joint:thumbup. Real easy to do, takes less than 1/2 hour...chock the front wheels if your on a slight incline, cuz when you drop the drive shaft it may roll away.:doh0715:
· my bko ate my money
:histerica:histerica:histerica i had to chase my BKO before it rolled into a lake when i first got it and greased my slip joint, :doh0715:
Bad radius arm bushings.
I'm going to check on both of these.
Thanks for the heads up on these :beer !
· Kitteh Commandaar!
OR you could put it in 4wd, make sure the hubs are locked in, and it is in park. ****DON'T DO THIS WITH AUTO LOCKERS**** At least I wouldn't recomend it. ;)
I would chock the wheels too if you're paranoid :thumbup
KC
