I have a really weird AC issue. My AC tends to cut out at random times. When it does it seems to blow like its on vent when its set on Max AC. Here is where its weird. If The truck gets up to high speeds, like getting on the interstate or if I hit a large bump the AC cuts back on. Anyone know what could be causing this?
Yeah, mine had vacuum issues too, that white tube was super brittle. Replaced the bulk of it and it is good.
Thats what I thought it was. I replaced part of the tube that was brittle a while back but I guess there is another part of it that I need to find and replace.
its the clutch on the comp when you hit high speeds that means the belts spinning faster that could help the clutch catch or when you hit a bump there you go the clutch catches. dont know if this it but i hope it helps, look at the clutch drive on the comp pump.
