The throttle sticks at idle when taking off from a start. Took t cable off throttle body to see when the prob is. Its definitley the t body sticking. However, when the engine is off the stick goes away and the tbody is smooth.
Any ideas?
OUT OF BUSINESS / M.I.A
Any ideas?
Are you sure it's not the orange plastic outer covering around the cable that's broken and jams? Just like mine does? When I hit the throttle lever when under the hood the orange sleeve hits the end of the cable and won't budge, though by using the pedal from inside it's fine.........
Why would it be fine with engine off vs engine running?
