96 bronco flasher died. The replacement el12 doesn't fit under the Oem plastic fuse cover. Is there a reduced height version?
This one works but I can't replace the cover panel
Sent from my SM-G960U1 using Tapatalk
There wasn't for my 82 when i had to replace the flasher
Yo mumzer,
We had same issue in our 96. First, we thought about using tiny self adhesive skid pad circular pieces along panel cover opening in dash. But decided not to take a chance in causing problems with the fuse panel circuitry.
So we stopped by our local Ford dearer and picked up a Motorcraft flasher that fits perfectly.
Call dealership before travelling there.
Also, for posterity;
150993
I got the Yellow Loud Flasher (without the extra wires and clip) at O'reilly's and it was a tight fit but the cover went on and hasn't fallen off yet. 1 for the Turn signals under the Fuse panel cover and 1 for the Flashers on the backside of the Fuse panel.
Novita Technologies 20 Amp 2 Terminal Loud Flasher Kit
Part #: LF12K Line: NOV Flasher-Hazard Warning/Turn Signal
☆☆☆☆☆ No rating value ☆☆☆☆☆ (0)
Part Fits 1996 Bronco
Select a store to see pricing & availability
Find
Hazard Warning And Turn Signal Flasher With Bracket
Amperage (A): 20 Amp
Bracket Included: Yes
Connector Gender: Female
Terminal Gender: Male
Terminal Type: Blade
Show More Show Less
Compare
Novita Technologies 20 Amp 2 Terminal Turn Signal Flasher
Part #: LF12 Line: NOV Flasher-Hazard Warning/Turn Signal
☆☆☆☆☆ ☆☆☆☆☆ 4 out of 5 stars. Read reviews. 4.0 (1)
Find
Hazard Warning And Turn Signal Flasher Loud Flasher
Bracket Included: No
Show More Show Less
Compare
Part #: EL12 Line: NOV Flasher-Hazard Warning/Turn Signal
☆☆☆☆☆ ☆☆☆☆☆ 4.4 out of 5 stars. Read reviews. 4.4 (9)
Find
Hazard Warning And Turn Signal Flasher Heavy Duty
Show More Show Less
Compare
Novita Technologies 12.5 Amp 2 Terminal Turn Signal Flasher
Part #: LL552 Line: NOV Flasher-Hazard Warning/Turn Signal
☆☆☆☆☆ ☆☆☆☆☆ 4.2 out of 5 stars. Read reviews. 4.2 (5)
Find
Hazard Warning And Turn Signal Flasher Long Life Flasher
Amperage (A): 12.5 Amp
Show More
Use the OEM part . The Junk yards are full of them
PS. Don't use Front turn signal LED bulds. Unless you plan on alot more work and $$
