1 - 20 of 92 Posts
So if its not one thing its another.......i just finished fixing the truck with the transmission and surging, NOW!!!! i take the plug they put on the transfer case motor spot to see if the shaft was there......quess what.....ITS JUST A VACANT HOLE so they didnt put the shift tube in........so now im looking for parts or a used transfer cause this is just stupid! just wtf
cause i think they just stripped everything and made it RWD
ill take a pic in a moment
Charlie don't surf..
'92 Ford Bronco XLT
wait, are you saying your transfer case is gutted?? not sure how that would be possible..the rear driveshaft is driven through the transfer case, so there has to be something in there..
ikr!!!!! but literally there is not shift tube :/ and mostliekly no shift fork
1994 XL, E40D, 5.0, rear lsd, front auto hubs
I assume taking the transfer case out is very easy, but tearing into it, as iffy as an auto transmission? I tore down two manual trannies (chevy S10 and 2004 GT Mustang)and it's pretty straight forward to fix major problems in those because you can see them. In auto trannies after watching videos of it I still don't have a clue . I imagine a transfer case is easy. It's like 3 gears in a box right? 2h 4l 4h ? Loooool. But seriously, can't be that bad. Do you still have the front driveshaft connected to it?u
Discussion Starter · #8 ·
yes it does, problem is that there is SO MUCH!!!! missing that what would be the point? id spend more rebuilding it then getting a used one
Discussion Starter · #10 ·
So...what happens when you shift to 4L?
when i bought it i though it was jus covered cause maybe there motor died, nope, most likely there case failed and turned it rwd only, took a peak in side and didnt see any chains
Sucks to be you brother. One way I found to go through pain is to project yourself in the futurw after the repair is done and try to imagine how it feels. It helps. Now here and get to work. Might not be that bad if they only removed the chains. I assume you have a 1356? This is for a 1356, electrical switch.
Discussion Starter · #12 ·
Discussion Starter · #13 ·
177481
This guy is local to me and is offering this transfer for 100$, i was thinking of rebuilding it in my free time, it was for his 94-95 bronco
Addicted to Junk
Buy it quick! I pay 85 to 150 (depending on which JY) for a JY transfer case that i had to pull off myself.
Driving Stuff Henry Built
Seems like a good choice. Unless you want to swap to a manual while you're at it. Even so, this could get you 4wd in the meantime. I'd grab it.
‘90 EB Full Custom build -Mega Truck Bogger
That sucks....I couldn’t give my 1336 away and scrapped it to a junk yard....nobody wanted it
Discussion Starter · #17 ·
it has a different connector end!!! D: what am i suppose to do!?! i would have to dismantle the one i have on the truck
Discussion Starter · #18 ·
177520
This is a similar picture to what the seller has,can i just change the "output flange" i think its called to the bronco one?
Yes the output shaft yoke can be swapped... you might want to take the yoke off before you pull the transfer case... the. Wait to put it back on when the new transfer case is installed... otherwise you need an impact gun to get the nut loose.
Discussion Starter · #20 ·
HAHAHA yup your right, if not its going to be a pain to get it off
any specific torque spec?
1 - 20 of 92 Posts
