1 - 20 of 20 Posts
IM FAT, YOUR UGLY!
Gonna do a junkyard run on payday to grab a few things.. Need to know what I can pull the front seats from that would be interchangeable with my 85 FSB? Something thats a direct bolt on or doesn't require welding. Prefer something adjustable and the ability to still get into the back seat.
IM FAT, YOUR UGLY!
:( guess ill just call the junkers once a week till i find a 80-86 FSB lol
caviler seats, there pletty of them out there. just need to drill a pair of new holes and shim the hieght.
it took me 5 min a seat
there now black
IM FAT, YOUR UGLY!
what year abra? and are they adjustable on the floor so they still go back and forth or at they in 1 spot?
these out of a 02, yes they go back forth. add a little leaver for passager side and it goes to the windsheild
ill post some newer pics on friday. from the bottom side
IM FAT, YOUR UGLY!
Discussion Starter · #8 ·
thanks for the advice Six but I really dont want a bench seat in the front.. lol
Abra, thanks alot.. Will check around for some :D
IM FAT, YOUR UGLY!
Discussion Starter · #13 ·
yeah they are the lowback bucket that hurt my back LOL
92-96 are high backs, very hard to fine in one peice
thunderbirds are everywere, if you go this way fine them with power everything. i had a set once, lost room to rear entrance.
personally, i've found that the seats from the 87-91 models allow the best access to the back seat for us big guys.
All you have to do is unbolt your current seats from the frame under it and bolt that to what ever you got. I know its sounds easy and I am giving you a smart answer, really it works. I used the lower seat frame, drilled some new holes in it and bolted on some new baja seats in my 85. Just use those lower frames and existing bolt holes. Hope that helps.
Practicing Infidel
My point exactly
If you're a big guy, you'll be hard pressed to find larger seats than a Bronco already has.
That thread, I linked to, discusses how to repair the ones you've already got by re-foaming them for renewed support.
Dirt cheap, real easy and well worth it (and you know they'll fit:toothless)
Sixlitre
My point exactly
Sixlitre
yup, the captains chairs i have in mine make it really difficult to maneuver into that back. but the 87-91's are easy for my big rear end lol.
1 - 20 of 20 Posts
