20081 - 20100 of 21866 Posts
95 Bronco, 351W, E4OD, 4.56 gears, 35x12.50x15 Patagonia MTs. 94 Bronco 5.0/E4OD/1356/3.50 gears.
Replaced the air flapper on the flexalite fan shroud and washed the Bronco.
86 BKO orig-5.0efi swap to 91 5.8efi w/AOD longtube w/2.5in to 3in hiflo cat 3in hp shorty flomaster
Pics?
No i don't, was in a hurry when I did it but ill do a little write up for how it went...
Pics?
1996 Bronco XLT 5.8L
Got my spare tire cover today. Looks like a factory cover from Ford. This place is located in Florida and shipping was less than 5 days! They make them in all sizes and many colors. sparecover.com/fordbronco is the site if anyone is interested.
This is where I got mine based on your recommendation @Tom S. Thank you!
Really good quality btw.
Sent from my Pixel 3 XL using Tapatalk
Yo! @BikerPepe'
or
Stainless with fittings. Outstanding. Thank you kindly sir. Not sure how I didn't at least find the LMC option. Have you purchased and ran these NPD pre-bents? Just wondering if I'm better off with the kit or the pre-bent for fit. Nothing special going on and the 400 should be identical to the 351 for this application.
@Desert Bronco no need for the JY trip but thanks again bud.
To begin with when i went to change the rotors the ones i had ordered from Hart brakes were the wrong ones although it had said they would fit manual hub 86 broncos. so i ended up returning those and getting some other Hart rotors that said they were for auto hubs (although mine are manual so not sure whats up there cause they fit). Once i got the right rotors i tore into it one evening after work...pulled the wheels off, took the hub assembly off. This is held in by a circlip on the splined axleshaft surface and a ring on the inside surface of the hub, might have to clean a bit of grease to find it... Then i took the spindle nuts off (there are 2 nuts with a toothed ring with holes in it in between the two nuts to keep everything locked together) and pulled the hub along with the rotor and caliper. Since i got just the rotors and not the hubs i pounded out the lug studs and seperated the two. I checked the bearings and repacked with grease and replaced the grease seal on the back side of the hub before i put the rotor on. As soon as i had taken the lug studs out i stuck them in the freezer to make reinstallation a little bit easier. Pounded the lug nuts back in to hold the rotor and hub together then stuck it back on and put the spindle nuts back on and torqued em down. I then pressed the caliper piston back in with a channel lock pliers (worked okay) and put the pads on. Put the caliper back on and then the wheel and all done...
link to the rotors i used- [FRONT KIT] Black Hart *DRILLED & SLOTTED* Disc Brake Rotors +Ceramic Pads F1687 | eBay
i really like them so far
Reactions: SRWillis
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual hubs
well,,, look into my project, the brake light switch tried to burn down the car, which could be avoided...... luckily- now I am in czech republic enyoing a production plant shut down (which I have to execute)
anyways, @BroncMom
here is pic for ya, sorry, got none from installation, but really giving the lower compartment a nice look:
the cover on left is driver side, the right one passenger, nicely fitting to heater box "snorkel".
good quality, easy install, as it has rubber on the backside.
If you place it correctly and push at the places where there will be screws you can mark the rubber and then have to use a screw driver pushing the hose through and it will be no hassle to install it perfectly in the original screw position, without any glue.
Pepe', I've used the prebent from someone but honestly can't recall who I got it from.
1978 Bronco Ranger XLT, 400/C6 92 K documented miles &1994 Bronco,XLT 85K original miles
Installed the Sniper distributor. Why couldn't Ford use an offset drive like Chrysler....
Wasn’t on the FSB per say, but it’s FOR the FSB, and I had a “little” help today, yarded the axle off the spare parts F150, still gotta pull the 4 inch pivot drops off the cross member but after the axles I’ll be needing a couple drinks and a hot shower for my shoulders and lower back.
Got it lowered with stands, blocks and I’ll put some more timber on the front tires cuz tomorrow my fat ass will be all the way under it without suspension on there, and no there not harbor fraud jack stands, there from the military when the father in law was in charge of the motor pool (perk was he got first dibs on retired equipment) about 35 years old, they have held up probably a combo of 100 different cars, trucks, vans, trailers and RV’s over the years
1979 Ranger XLT 400m T18
Picked up a hitch mount bike rack from CL since my old strap on unit doesn't fit with no body line to hook into at the top of the back. It should allow me to take the kiddos to the park to bike without hooking up the trailer.
That’s gotta be the best accidentally “dirty” sounding thing I’ve ever read on here yet!! :LOL:;)
cwegga what ever you do with your strap on's - seems to make you happy!!! o_O
Did do nothing to the car, but ordered fittings allowing me to install a fuel return line to the tank.
The part in the pictures will be connect through the tank wall after drilling a hole and then a fitting to press the return hose on.
ordered all in dash 06, equaling to roughly 8mm inside diameter of hose, which is the same as of now.
162485
1989 Bronco XLT 351W with C6, manual locking hubs. 6” suspension lift with 35” Cooper tires
Haven’t done much lately. Kind of needed to take a break and miss it lol. Got my “rare” 89 grill badge in to find out my new grill from rock auto used the newer badges which is convenient but would be AWESOME if they told you that when you ordered. Plus eBay doesn’t do returns apparently so I’ll be selling a mint 89 badge if interested lol. FYI, no one makes new ones lol.
The Tennessee Warden
Too big? You may have to buy a whole grille for the badge and then sell the empty grill to get some money back.
No it’s just completely different with that “skirt” on it. I’m sure someone will need/want one. My old grill and badge are going to be wall art in the man cave lol.
Wow! That looks clean! really nice.
give that to me, now 🎃
Right here .. What are the measurements on it?
I’ll check it out when I get home and message you some pics with a tape measure on it.
