Thanks. I'll check them out.
Took it for a spin in the first snow fall of the year and ducked taped my ash tray closed. Every stop at a light it slides right out.Lets get a sticky!!!
It's easy, tell us anything you've done to your Bronco today. It could be as simple as staring at it, or as complicated as finishing a SAS, doesn't matter
I washed mine today, and tried to fix my loose passenger side mirror
Probably a good idea to carry a roll of DT in the truck at all times.Took it for a spin in the first snow fall of the year and ducked taped my ash tray closed. Every stop at a light it slides right out.
Maybe a piece of the windage tray?Had the pan out and pPulled mystery metal out of my oil pickup. It's aluminum and not a rod or main bearing. Doesn't look like a cam bearing, but need a borescope to make sure. No spun bearings but some stuff went through the engine. Any guesses?
Hey stranger! 🍺Might have dodged a bullet, for the time being.
Last Tuesday afternoon, we were driving the Bronco to the in-laws to spend the Thanksgiving holiday. Wife was driving........ fast...... 1981 Bronco not made to go fast. Eventually, noticed some strange shifting issues with the C6. Now, I know it's an old vehicle, not sure if anything has ever been done to the C6. But I think the tranny was getting hot. Anyway, we turned around and made it back home, to go back on Wednesday with the 1995 F250 PowerStroke.
Looked at it today. Not sure if maybe there was an issue with the kick-down linkage making it not want to shift easily into 3rd gear?
I ended up draining the tranny, spliced in the transmission cooler that I had removed from the 1995 F250 (had installed a much larger one on the F250), and added an in-line magnetic filter in the return line. So far, so good.
(Then, went inside and had a gentle discussion with my favorite wife about driving her beloved Bronco too fast....)
We'll see how it goes form here, but we are setting aside money for a new/rebuilt transmission.
My response to that is always, "Stranger than most!"Hey stranger! 🍺
Thank you! I am glad you posted that picture....... I have a 1969 Falcon Futura wagon...... the rubber wiper on that outside seal is non-existant and it has been impossible to find a replacement part. I am going to order one from the Bronco catalog and see if it can work on the Falcon wagon........ if not, I can always install it on our Bronco.View attachment 150793
redneck outside tailgate weatherstripping it’s rainy season
Hey bud,Might have dodged a bullet, for the time being.
We'll see how it goes from here, but we are setting aside money for a new/rebuilt transmission.
Previously, the only cooler was that section of the radiator. Here is the one I added... pic from before I removed it from the F250. Installed in the Bronco in the same area:Hey bud,
If your rig didn't have an external cooler, putting one on like you did should help keep it cool. Also, the kickdown linkage being out of adjustment would only affect the downshift when you are already rolling in third gear and accelerate to pass or merge, etc. The filter will help, but you may want to drop the pan (save your new fluid!) and put in a new pan filter (and gasket). Good luck!
Gotcha - didn’t realize you already changed the pan gasket/filter. The C6 is a tough transmission so hopefully it will still serve you well.Previously, the only cooler was that section of the radiator. Here is the one I added... pic from before I removed it from the F250. Installed in the Bronco in the same area:
Probably 2 months ago, I changed the fluid and installed a new filter/gasket. When I drained the fluid this time, it still looked nice and red, so I didn't think it needed a new filter now..... I really think this is just a stop-gap measure..... won't be surprised if the tranny gets swapped sometime soon. I plan on talking to a shop today about it, see what I need to plan on. I am not a transmission guy, and wouldn't have the facilities to get it done, other than in the open in the back yard. I think I would gladly pay someone to do this job.
