I've got a 93 Bronco XLT 5.8 e4od with 248,000 miles. All stock, all original. My rear main seal is leaking now. I cannot do it myself. The shop in town will charge $450 parts and labor. I know everybody says if it aint broke dont fix it. Runs pretty strong just has a high idle problem in park and neutral and oil leak. I am curious if I would be better off to just remove the motor and do a rebuild or fix the rear main seal and do a rebuild when it breaks. Either way it's not in my budget but I will make whatever sacrifice to make it happen. Thanks for any advice.
Ken
Roller rockers are gay
how much is it leaking? if it's not some ungodly amount, i'd just let it leak and add oil until you need a rebuild on the engine or trans.
about 1 quart approx. every 1000 miles. and it's not my daily driver. I was reading for a small leak that Lucas additive may stop it?
MARBLE GARGLER!
My Bronco has 200,000 miles on it, The previous owner {who is a friend of mine} Faithfully used 10/30 wt. oil and the rear main was leaking. For a shop to fix it was expensive so he sold the no rust/no dents Bronco to me for $500 bucks. i switched the oil to 15/50 weight Mobil 1 and now it doesn't leack much. For the rest of the leaking I just made a 6"X6" Engine diaper and strapped it up under the Torque converter drain plug hole. About once a year I replace the 6"square diaper thingie, done- If you dont want to bear the expense of synthetic oil you can use 20/50 Valvoline, Pennzoil or Chevron brand oil. and if you have that many miles on the transmission I suggest getting an axillary transmission cooler on there and new trans fluid. I am NOT a firm believer in "If it aint broke don't fix it". I say Fix it before you are totally screwed !
