Well, more adventures in bronco land...
I noticed (when my starter went bad) that my driver's side rear wheel was dragging (couldn't push the bronco)
I needed to check the brakes before MD inspection anyway, so here is what I found:
Here is the one that was hanging up. If you look in the drum on the floor, you can see the pieces of pad that had come off of the rear shoe, slid around inside of the drum, and wedged into the front shoe.
No wonder the wheel didnt want to turn.
That's just a simple replacement of the shoes. No problem.
Now, here is what was under the passenger drum:
That's not brake fluid. I'm pretty sure it's axel grease/fluid/oil/whatever
Here is a closer shot:
Time to brake out the Haynes manual and figure out how to fix this thing!
