Yo gentbronco,
Following from 1996 All F-150, F-250, F-350, F-Super Duty and Bronco Vehicles Equipped with 4.9L, 5.0L, 5.8L or 7.5L Gasoline Engines, and 7.3L Diesel Engines Workshop Manual @
http://www.diesel-dave.com/vehic/manual/stj/s
Section 03-00: Engine, Service | |
SERVICE PROCEDURES
Engine Oil Leaks
When diagnosing engine oil leaks, the source and location of the leak must be identified prior to service.
Fluorescent Oil Additive Method
- Add Rotunda Gas Engine Dye 164-R3705 or equivalent to the engine oil. Use 29.6 ml (1 ounce) of fluorescent additive in all engines.
- Clean engine with a suitable solvent to remove all traces of oil.
- Run engine for 15 minutes.
- Stop the engine and inspect all seal, gasket and galley plug areas for leaks using Rotunda Oil Leak Detector 164-R0756 or equivalent. A clear bright yellow or orange area will identify leak. For extremely small leaks, several hours may be required for the leak to appear.
- NOTE: For minor gasket leaks tightening the retaining bolts may resolve the problem.
Service all leaks as required.
Next up to bat is;
Section 03-00: Engine, Service | 1996 All F-150, F-250, F-350, F-Super Duty and Bronco Vehicles Equipped with 4.9L, 5.0L, 5.8L or 7.5L Gasoline Engines, and 7.3L Diesel Engines Workshop Manual |
SERVICE PROCEDURES
Leakage Points
Examine the following areas for oil leakage.
Underhood
Valve cover gaskets (6584)
Intake manifold gaskets (9439)
Head gaskets (6051)
Oil bypass filter (6714)
Distributor O-ring
Oil level indicator (dipstick) tube connection
Oil pressure sensor (9278)
Cup plugs and/or pipe plugs at end of oil passages
Under Engine, with Vehicle on Hoist
Oil pan gasket (6710)
Oil pan front and rear end seals
Crankshaft front seal (6700)
Crankshaft rear oil seal (6701)
Engine damper keyway (damper to damper bolt/washer interfac
