1 - 8 of 8 Posts
I was wondering where to tap in to get power when high beams are on? Thanks
TTB Hater of course
If in the engine compartment, the appropriate wire feeding the plug at the back of the bulb. I just use the 3M connectors which pinch the wire and then allow you to plug a male spade connector into the back of it.
thanks keith.
Is there a way to tap into the fuse box somewhere? I looked in the manual, but i didn't see any fuse for high beams.
The headlight wire seems like a pretty small wire to be tapping into.:shrug
FSB warrior
Midnight Rider said:
tap into the high beam wire and then run to a relay that has a higher current carrying capability.
what he said....
what are you trying to power anyway? Using that wire as a relay turn on line is devinitely the way to go.
1 - 8 of 8 Posts
