Urban Assault Bronco
i have 6 quarts in there now and at operating temperature it doesnt even show up on the dipstick.... so how much does it hold?
It will all depend on if you have a different cooler and what not. IIrc it will hold approximately 12 quarts. Just keeping adding and checking until you have it full. Check in your Haynes or Chilton manual, it will tell you total capacity in stock trim.
ok cool. thanks
That AINT 12 qts in the pan, it is 12 qts TOTAL. About half of that amount stays in the converter.
In other words.....if all you did was drain the pan, don't dump 6 more quarts in there. About one more aught to do it.
Like the man said, put in another and recheck.
DGW
well transmission is out of another truck, it was drained, and the torque converter as well.
should have filled the TQ converter before you put in on the trans. but a big bell C6 should hold about the same as a small bell C6. all the internals are the same
