1 - 13 of 13 Posts
Holding in passenger door regulator
164450
Factory rivet , if your pulling the reg, you’ll need to drill it or grind it.
Reactions: cobrajoe
If you check around you can find a loaner rivet tool ( regular one is too small) or find a shop that will rerivet It in for a small fee once you got it all prepped.
Anything wrong with just a nut and bolt?
Ultra Premium Member
Yeah, as said, 1/4" rivet, the new window regulator usually comes with new ones, but most people don't have a 1/4" rivet gun, so they bolt them in place. If you take a punch and knock the center of the rivet out, it will be easier to drill.
Reactions: jfourdyce
Discussion Starter · #8 ·
Ok, we’ll, pretty sure I’ve got to replace the reg. The motor spins when I desperate it from the reg, and the reg turns freely.
but bolted together it doesn’t want to move.
also, the window stays up when not hooked up.Is that ok or do I need to replace the seal?
If the regulator moves freely, the plastic gears in the window motor may be bad. If you put the load of the regulator on it, they may slip.
Discussion Starter · #10 ·
the motor won't even turn when I have it on the reg. for 120$ I guess i'll just replace it.
but should the window stay up without being connected to the regulator? or should it slide down under it's own weight?
Charlie don't surf..
'92 Ford Bronco XLT
Assuming your question is should the window stay up without being connected to the motor? If so, yes..The actual regulator is attached by the arms to the window..
Discussion Starter · #12 ·
so it is ok that there is enough friction in the seals and tracks to hold the window up?
'92 Ford Bronco XLT
Actually, I stand corrected..I just replaced the passenger side motor a few months back..now I recall that the window did want to slide down with the motor removed..
1 - 13 of 13 Posts
