1 - 20 of 28 Posts
Use the search feature. Plenty of threads on this... use Oil Weight or if you are trying to decide between synthetic and standard oil, search Synthetic Oil... those should give you the info you are looking for.
10w40 is what i run and i have no problems. if ur leakin, 20w50 with a quart of lucas
You should just not post anymore.
If you're leaking, fix the leaks dumbass. :twak
Satyr of the Midwest
Yellow.
I think Ford wants people to blow their older engines. 5W-20 on a 100k-mile small block? :twak
It's BTW Not AKA!
That alone should be grounds for banning. :smilie_slap
Manual for my Bronco/302 and F250/351 say 10w30 for the 302 for general temperature range, and 5w30 for the 351.
It's BTW Not AKA!
run anything you want, as long as it is oily.
Does that mean I can actualy put Mike's sheets right into the fill neck and the engine will run?
1 - 20 of 28 Posts
