If you look at this list from TunerPro, you will notice Not One Single F-150 or Bronco ECM is supported......
Ford (requires v4.13 or higher)
ID
Bin Definition
Last Updated
Application
T23B
T23B.xdf
3/13/09
8UA - 88 2.3l Thunderbird auto
LB3 - 87-88 2.3l Thunderbird auto
LA3 - 88 2.3l Thunderbird 5sp
Definition maintained by Dex
GUFA
GUFA.xdf
4/12/08
8LD - '88 - '93 5.0l Mustangs
A9S - '88 - '93 5.0l Mustangs
GUFB (A9L)
GUFB.xdf
4/12/08
A9L - 88-92 Mustang 5.0L
A9M - '89 - '93 5.0l Mustang
A3M - 93 5.0 Mustang
A3M1 - 93 5.0 Mustang
A3M2 - 93 5.0 Mustang
D3D1 - 89-93 5.0 Mustang
S0Z - 89-93 5.0 Mustang
X3Z - 93 5.0 Cobra
GUF1
GUF1.xdf
4/12/08
A9P - '89 - '92 5.0l Mustang auto
A9T - '89 - '93 5.0l Mustang auto
C3W - '93 5.0l Mustang auto
C3W1 - '93 5.0l Mustang auto
8LF - '88 - '93 5.0l CA Mustang auto
CDAN4
CDAN4.xdf
1/23/06
96-97 4.6L Mustang, T-Bird, Crown Vic
96-97 3.8L Mustang
NOTE: This XDF is for "full" binaries. Only 256k 0189 EEC-V files should be used.
CRAJ0
CRAJ0.xdf
8/15/06
LAQ2 - 98 3.8l Mustang
AOL2 - 98 4.6l 4V Mustang
AOL3 - 98 4.6l 4V Mustang
CBAZA
CBAZA.xdf
10/1/07
L4C1 - 94-95 5.0l Mustang 5sp export market
J4J1 - 94-95 5.0l Mustang Cobra 5sp
T4M0 - 94-95 5.0l Mustang 5sp
U4P0 - 94-95 5.0l Mustang auto
W4H0 - 94-95 5.0l Mustang auto
ZA0 - 95 5.8 Mustang Cobra R 5sp
FCL0 - 95 5.0l Mustang auto Japan market
S4M1 - 5.0l auto
LUX0
LUX0.xdf
12/12/07
DA1 - '87 Mustang 5.0L
DB1 - '88 Mustang 5.0L
L8
IAW048_01.xdf
3/19/08
Sierra Sapphire 4wd Cosworth L8
L1
IAW045_01.xdf
3/19/08
Sierra 3 door Cosworth L1
L6
IAW045_06.xdf
3/19/08
Sierra Sapphire 2wd Cosworth L6
HWAD3
HWAD3.xdf
8/21/08
6DBD - 1998 Futura/GLI, 4.0L, auto
6DNB - 1998 GLI, 4.0L, auto
6TEE - 1998 XR6 Ghia, 4.0L, auto
May also work with:
6DAC - 1998, unknown, 4.0L, manual (HWMD3 strat.)
6DMA - 1997 XR6, 4.0L, auto (HWAC2 strat.)
(Requires 256KB bin with first 8KB to be null-padded)
N4AGB
N4AGB.xdf
8/26/08
4DBG - 1995 Futura/GLI, 4.0L, auto
4TEG - 1995 Futura/GLI, 4.0L, LPG
May also work with:
4TBD - 1994 Fairmont Ghia, 4.0L, auto (N4AG9 strat.)
NVMG8
NVMG8.xdf
9/18/08
1996-1998 Ford 5 Litre Falcons & Fairlanes
6DFC 1996 EL XR8 manual HO 5ltr
6DFD 1998 EL XR8 Manual HO 5ltr (Explorer Intake)
6DGC 1996 NL Fairlane Ghia auto HO 5ltr
6DGD 1997 EL Fairmont Ghia auto HO 5ltr
Provided and maintained by Jaysen Anderson
Jaysen's notes:
A lot of these parameters are still untested, Ive tried the more common ones ie WOT fuel & Spark, idle rpm etc. However if you choose to play with these, be aware of that you do so at your own risk.
The 6DFC & 6DGC both work on the 6DFC xdf file, and 90% of the parameters work for the 6DFD & 6DGD, however I will get a revised xdf for the FD&GD bins asap.
