1 - 11 of 11 Posts
I am getting ready to replace my radisu arm bushings on my 89 EB, stock Bronco. I have no clue who or what to buy Any help would be appreciated.
Bronco-Jeff
Poly bushings if you want longevity and don't mind the squeaking.
Rubber if you want noiseless operation, but they supposedly don't last as long as poly bushings.
Also rubber will compress more allowing for more suspension travel than a poly, but on TTB that is probably not going to matter anyways.
Poly radius are bushings don't squeek. I never even grease than and have not had any problems.
Stay away from poly the Spicer bushings. There so ****ing hard thay have been known to snap off the 3/4" bolt from not allowing them to flex
Practicing Infidel
Ditto
I used Energy Suspension polys. No squeaks 4 years later
Sixlitre
Poly bushings that are gray or black have graphite added to the polyurethane and don't squeak. Colored red/yellow etc no graphite and may squeak.:thumbup
Bitchin.
i wouldnt worry about poly unless you're replacing the axle pivot bushings too. otherwise its like bolting on a 4 inch exhaust to a rice rocket... no sense.
i run TRW ploy bushings from advance auto...mine are red but i didnt grease them and they dont squeek.
Engineer
I just put in carquest poly bushings. They dont seem too bad or for that matter any different that my originals
1 - 11 of 11 Posts
