1 - 9 of 9 Posts
MARBLE GARGLER!
I have a 1990 351w bronco with the long intake air tubes going to the air filter box and I want to do some kind of heat barrier wrap to keep the intake air a little cooler, what do you recommend ? should I combine the wrap with a heat reflective spray like Thermotec sells ? I do not wanna use a hardware store wrap like fer waterheaters-
green ones make me horny
foil insulation. itis a metallic silver insualation they have at home depot. also get some heat resistant tape for it as well. it looks like foil as well
I used the same thermo tape that is sold at hardware stores and it is clean.
It's BTW Not AKA!
I am sure it can be had cheaper at the home improvement stores.
MARBLE GARGLER!
But is the stuff at Summit racing the correct stuff ????
it would work
That foil stull that looks like bubble wrap is pretty good at keeping radiating heat down. Wrap it up with a few layers and use the foil duct tape.
You're probably not going to see any difference with doing it, but congrats on the ambition.
1 - 9 of 9 Posts
