1 - 12 of 12 Posts
What size thread is the pipe on the back of the motor. I believe it connects to the air pump. It connects the the back of the cylinder heads. Most of my emission stuff is gone. When I put the new engine in, the air pump seized up and I just re-moved it. I capped off that pipe, but the cap fell off and now it sounds like crap. So I need to redo it again
my bko ate my money
anyone get that thread size?
i dont have the time to wait for ryan to ship em, so i need to head to home depot to get some pipe caps for the back of the heads,
FYI: my emissions equip. failed along time ago so it was removed and since i had GT40 heads with NO ports i didnt need it anyway, now i have been forced to put the E7's back on and NEED to cap the ports since i dont have any kind of emissions equipment on except for the EGR, i kept the EGR
need the thread size
any help?
my bko ate my money
yeah shes a biggin, 9/16 was too small and 5/8 was too big, then i couldnt get the thread pitch right, it was a headache and i wasted about $10.........then finally said fawk it and placed my order with Ryan
thanks for the help tho guys.......
There's two holes. Ones the port, the other is where the bolt goes in to hole the crossover tube on. Buy the cover plates and use the 5/16 bolt like I said.
So no FAIL.....:haha
my bko ate my money
:lolup
yeah i was tryin to get a bolt to thread in the threaded ports, thought about a cover plate and thought about turning the crossover backwards to block it but didnt want to risk a leak and have to go back, got to throw this thing together and runnin in 30 days due to a foreclosure :cry
atleast ill finaly get to drive it again after almost a year :banghead
I don't think you can turn it around backwards due to the check vavle might hit the intake :shrug But you could cut and weld the ends shut.
my bko ate my money
its alright, not only did i order the plugs but i also got some resistors and stuff to complete my harness, next ill hit him up for a 3G and maybe a new tuned MAF but thatll come later once everything is straightened out and runnin
1 - 12 of 12 Posts
