1 - 4 of 4 Posts
I have a 1995 bronco with a 4" lift 33" tires warn premium hubs no rust did plugs fuel filter fuel pump new belt. My air pump is squeaking but I plan on using a 5.0 elimator bracket. The question is where do I start. What shold I do frirst. I want to do full exhaust no cats y pipe headers and cat back single three inch I new rims and tires new shocks but I was also thunking gt40 heads and a bigger cam. What should i do
Thanks max
si vis pacem, para bellum
do what needs to be done first then go with performance and vanity
Satyr of the Midwest
Leave the cats alone. The camshaft is the LAST thing to change on the SBF, and a higher power band is the last thing you need with a small engine and large tires.
1 - 4 of 4 Posts
