No avatar required
I'm heading up to pick up my $100 Bronco. I don't want to lug a ton of tools with me, so what size wrench(s) do I need to remove the driveshaft once I get it on the dolly. I'm already taking a floor jack and two smaller tires to get it on the dolly easier. It's an 84 with a 4 spd.
No avatar required
Thanks. I planned on grabbing a handful of wrenches. I just didn't want to leave the one I need at home. I know it's different than my 79.
FSB warrior
dont forget a 12 point 5/16" Thats one you wouldnt likely have taken unless I told you. Good ?
FSB warrior
Miketnf150 said:
If all you are doing is taking off the driveshft then you will need a 12 point 3/8" wrench or somewhere there abouts. Just take you a few small wrenches around that size.
Its 5/16... I had to find a socket for it, cuz all you get in 98% of sets is 6 pt 5/16
No avatar required
Thanks guys, I crawled under a co-worker's '86 and sized them up, 12pt 8mm or 5/16. Now if the "tow" treuck would cooperate I'd be good. Just had all the rear bearings in the wife's Expedition replaced and today on the NJ Turnpike the pinion seal started to piss oil all over the place. :banghead
