what type of gas do you use in your bronco?
  • mid-grade unleaded w/ seafoam (or other additive)
    Votes: 0 0.0%
  • premium unleaded w/ seafoam (or other additive)
    Votes: 0 0.0%
1 - 20 of 24 Posts
Regular... unless i'm going snowboarding then i mix Mid and Premium
Regular...and make it Chevron with Techron!! Just look at my name and you will figure it out..but in all honesty...Chevron is one of hte best gases you can get out there.....and that bottle of techron you can add....whooo
Roller rockers are gay
i use regular, always. i used mid-grade for one tank and i got 2mpg better, but i just broke even with the cost, so who cares.
and about every 2 months i run a can of seafoam through the tank.
Past Bronco Owner
The old Beater motor pinged on regular so I used mid grade. New Ford Long Block is waiting for me to pick it up Saturday, I'll see how it runs on regular after a couple tanks for break in.
That happened in my area once. For a day.
I use regular. I got no pinging or anything, so no need to step it up.
Performance wise, it doesn't make much of a difference. The higher the octane, the higher the resistance to burn. Most people will use higher octane under a pre-ignition type circumstance. With all the cars I drive, unless there's a problem, I use what the owners manual tells me to.
I run regular only, with the stock engine anything higher is a waste of money.
I run Hightess since My motor has a 12.5to1 compression :beer and no its not stock lol
1 - 20 of 24 Posts
